Will L.
Air pocket most likely
Thanks for sharing this. Might be a low cost option. I've been looking at canned tuners, because I really don't want a full blown tune. Currently the controller works of a set of relays for that ground the trigger wires. One ground and the fans are on low. Ground the second one simultaneously and both fans come on high.On your cooling fans, you can bypass the ECM on them without any ill effects or even add an extra controller keeping the ECM in the loop. I have this controller on my 95 controlling the electro-viscous fan clutch, but it's made for electric cooling fans. it's design is for dual fans and includes an override for the AC.
This one uses a sensor with 1/8" pipe thread. Haden also offers the same controller with a "stick in" sensor that you push into the fins of the radiator if you don't want to drill and tap into a coolant passage on the engine.
Amazon.com
www.amazon.com
Does that whenever an amazon product is linked to this site.Thanks for sharing this. Might be a low cost option. I've been looking at canned tuners, because I really don't want a full blown tune. Currently the controller works of a set of relays for that ground the trigger wires. One ground and the fans are on low. Ground the second one simultaneously and both fans come on high.
Not sure why this post is automatically putting in the below comment. Doesn't even show up on my post editing page.
Another assumption, when I am in 2wd nothing spins up front right? We have our trip to SC in 5 weeks.Probably- expect to see not just the bearing but gear damage
Which gear box did you go with? Anything special or just auto parts whatever?Got the steering box swapped out today. Should have been a cake job but the pitman arm fought me. So hard to get a socket on it with the lower large grossmember and a-arm bracketry right in the perpendicular path. Ended up removing the box from the frame, then pulled the pitman arm.
View attachment 92758View attachment 92759View attachment 92760View attachment 92761View attachment 92762View attachment 92763
I shopped around a lot. Looked at all local box stores. Looked into supposed red tops, that are now not as highly rates but cost a fortune. Also looked into blue tops.Which gear box did you go with? Anything special or just auto parts whatever?
I believe the closest is Buffalo, but I will look into.@DieselSlug is there an LKQ in your area? if they show one in their system, they will ship to your local store or can ship to you. they also provide warranty too
the diff might be the same but possibly the connectors for the electronics could be different
I went on RockAuto and compared a 2002 Silverado 4wd actuator to my 2005 Yukon XL 4wd actuator and they are both denoted as "square" plug with the same GM part #.That’s an odd one.
My brother swapped a front diff on an 04 Tahoe and his donor came from an 05 Silverado. So I think you should be fine with at least 03-07c. I’d the electrical is different than you might be able to just swap the actuator from yours to the donor if it’s in deed different in the 99-02 models.
05 seems like an odd year for a break like that. I could see 03-07c being different than 99-02.
