- Staff
- #61
How about for the Duramax's?
I always ran a duramax filter on my 4X4 6.5. Fit great and held a little extra. The two wheel drive 6.5's can run a BIG filter though.
I run a wix 51794 it holds well over 1 quart of oil.
Looks like a large filter, but if you care it does not have the anti drain valve $8.50
51794
PARTS DETAIL
Principal Application: Chevrolet and GMC Trucks (73-93)
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 7.822
Outer Diameter Top: 3.674
Outer Diameter Bottom: Closed
Thread Size: 13/16-16
By-Pass Valve Setting-PSI: None
Burst Pressure-PSI: 270
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 21
Not sure what you mean about price?It has no place to drain back to. The threads on the filter go straight up. I do not see it being a problem.
Im not 100% what they mean unless its to prevent oil from draining out of the oil pump.
If it is I got a filter-mag wrapped around half of it.
What is up with the price?
I never looked at oil flow paths, but I know alittle about the way liquids behave. Im guessing at a theory: once engine shuts off the weight/pressure inside the filter is greater because the oil is above and since its not a closed system it will self level. All the oil is going to find the lowest spot it can. If the dirty oil has a way to flow back to the pan it will. The valve would/should stop any self leveling on that side of the circuit.
Just a theory though.
I never looked at oil flow paths, but I know alittle about the way liquids behave. Im guessing at a theory: once engine shuts off the weight/pressure inside the filter is greater becausethe oil is above and since its not a closed system it will self level. All the oil is going to find the lowest spot it can. If the dirty oil has a way to flow back to the pan it will. The valve would/should stop any self leveling on that side of the circuit.
If a guy switches over to Synthetic . . .
