A 6.5 factory crank will ring like a BELL.
The Old ring its steel, thud its cast is not always an indicator.
The Optimizer cranks are of better material than the original GM shafts.
My crank is from the GoodWrench engine that came in the truck.
It rings good, has no mag indications but I am going to use a SCAT steel crank just because I want to sleep well at night.
Just too much work to keep redoing this damned thing.
I am tired of wrenching on that beast, I want to go out and get in it and drive it, not crawl under the hood with tools.
With the availability of top notch parts, it makes zero sense now to rehash this with questionable stuff.
Back a few years, all you could get was more GM junk and the great possibility of another failure was always present.
My feeling is that with a KNOWN good piece of iron to work with, why not use a good crank and heads just to be sure.
The last debacle cost me a lot of $$$ and got me nowhere.
The 94 Burb, luckily had a solid 599 Block and the clearwater heads seemed to be fine.
Just can't afford to do this thing a 3rd time.
Missy
