Turbine Doc
Just Another Diesel Guy
Ok straight up per Todd/Bill is good for getting one running, now you need to tweak it a little, maybe 1mm toward the pass side see if it helps, you have IP turning tools or you just doing this by hand?
I plan on taking it to GM and getting it done properly when i get off my 3 week shift here but until then i was more so concerned with what kind of damage will be done by it being timed improperly...
I don't have the proper tools to get in there and do it properly...
I i was more so concerned with what kind of damage will be done by it being timed improperly...
I'd see if somebody local has the tools, most dealers don't have a clue.
Youll need AutoEnginuity, or CarCode, or Tech2 scanner for OBD2. Or you can just run the KOKO procedure now and see if it codes. If it codes move pump back towards passenger side, clear code and run KOKO again. As long as you can get to the IP nuts you can get it done. It might not code, but do you know what TDCO value was before?
X2
plus most independent mechanics/shops that have been around a while have a scan tool they may plug in and read your codes/TDCO for with you and the 2 of you can set it together, quite a few members in Sask possibly a good time for you to meet one of them that has a scan tool
A inexperienced independent mechanic if you are in a bind for time would be the way I'd go, GM mechanic will try to find something "wrong" and won't be able to get it timed until the "wrong" is corrected.
