buddy
Active Member
The lift pump sticky covers the drain. Its the tube coming off the valve on the t-stat cover, the same place you can easily test LP pressure. It doesnt really drain the filter bowl when you run the LP, just pushes out all the stuff in the bottom and replaces it with fresh fuel. You should do this once a month perhaps to pull out any water. But some people go the extra step when changing filter to suck out whats in there with a pipet or vacuum bulb turkey baster type deal.
