Odlaw
Redneck
OK, removed the cluster and hand cleaned each pin with a q-tip and contact cleaner. Sprayed out the connector. MIL still lit.
Can any of you guys point me to a schematic for the MIL?
Thanks again.
Smitty
I just had another thought, it appears that I might have two problems. The first time oreilly's read the code it didn't give a Pxxxx number just verbage referring to loose/faulty connection (or something like that). After I found the bale connector (which I noticed while cleaning, it was not the whole plug that was at an angle just the blue clip that holds pressure against the wires/seals - so I don't know if that was a problem or not). After I fixed that the light went out for about ten minutes so I went back to oreilly's and that's when they read the PO650 code. Maybe the first error was referring to the connection of their analyzer??
Oh, and I just found this from a GM service bulletin
"ECM replacement is not suggested for P0650 set by itself. ECMs returned and inspected by engineering have been found no trouble found. Most P0650 codes have been repaired by either a wiring or IPC repair."
What's a IPC repair?
Thanks again.
Smitty
