Husker6.5
Oops, break's over, back to the slavery on the assembly line!
YUP, all kinds of available sizes of pilot bearings and bushings, if a person would rather run the bushing.Pilot bearing diameters (outer and inner) for the end of the input shaft/crankshaft hub would be the only issue left, since your custom clutch would address the spline count/diameter issue.
I guess the next thing I should install on My truck would be a lift pump pressure gauge.It has fuel pressure though which is the weird part. We will see tomorrow I guess
Well that sucks. What kind of fuel pressure does the lift pump make without the engine running? Also, did you install a new tank or did you add the sump to an old tank? Maybe you sucked something into the lift pump?Tragedy has (potentially) struck and the truck (possibly) needs an injection pump.
I was driving home Monday night following another successful Moe's Monday with a regular group of fellow diesel buddies (the "Moe's Bro's") when I noticed that under acceleration my fuel pressure was dropping. The truck was running normal for the first 10-15 mins of the 20 min drive and I wasn't sure what to make of things. Keep in mind the sump install had been completed Friday (spoiler: 12 micron is too much for a pre-LP filter) and the truck had been mostly normal since. Anyway, on my ride home I noticed that I could get pressure down as low as 3psi, then it would slowly come back. So in the last 5 mins that I drove the truck, I did probably 4 WOT runs of 10 seconds each and it happened each time. On the last run, the truck began to sputter on the top end which corresponded with the low fuel pressure. So I decided to just take it easy and limp the truck home to figure out what was going on.
Well the truck had other ideas. Accelerating up a small hill at probably 20% throttle, the truck continued to spit and sputter, and fuel pressure went down to 5psi despite the light throttle. The truck coughed a couple more times and then shut off. Cranked but wouldn't fire. Tried a new PMD I keep with me, same thing. So we towed the truck the last 2 miles home and now she sits in the driveway. I have a 32 micron filter to change out, and we need to crack injectors and see if they are getting fuel. I am suspecting/hoping its the IP.
I think that @Big T can possibly help you with that.Thanks for the tips on the battery connections guys. I will be cleaning them this week.
I called PureFlow (Raptor mfr) today to discuss my pump. Long story short they are stepping up to the plate and replacing it under warranty. A huge stroke of luck! Very impressed and grateful for their customer service. Should be here later this week to install. Prior to installation I intend to flush the tank as much as possible to ensure the best possible scenario for the pump.
I am gathering parts for the 11.5" AAM install and need to figure out brakes. I have always been under the impression that a stock MC can be used with a proportioning valve when running disk brakes on a GMT400. Some internet searching muddied the waters slightly and now I am not as certain, so now I ask: What parts should I use for my brake system?
