Letting my sister drive - "F" engine w/ "S" stamp
I used a 100" at first, after a couple of months the belt had stretched to
limit of the tensioner - I switched to a 99.5" Gatorback, # 4060995 -
it was tight going on, but good now
I would use a shorter belt. On my 96 the belt has stretched to max on tensioner. I have my home made TM set at about 12 peak, and I have not coded yet. It will run about 10 on hard acceleration, and 4-5 down the road.
For a 96+ most likely 100" or 99.5"
On a 94-95 a 101" most likely. we have different brackets and setup in those years. maybe 100.5"
Typically at the store it will be labeled 1010 for 101", or 1005 for 100.5", 1000, 995etc.
