- Staff
- #21
Hey your sis is cute. If she redlines everything, I'd like her phone number.![]()
There is always one in every crowd! ):h :thumbsup:
I'll reteach my sister, and teach my g/f how to drive a stick.
This is 2 different people, right?![]()
:nopics: Need GF pics too!
Just funning with ya. After 17 years of marriage.....well let's just leave it at that. I'm sure lil sis make some guy who enjoys training very happy.
Forest, your younger sister wasn't too happy with her big sis at the moment of the pic):h
You want vacuum at the turbo wastegate, or no boost. Try running the line that comes from the vacuum pump straight to the wastegate actuator, with any rubber line for simplicity. If you get a lot of boost then there is a leak or failed boost solenoid. If not vacuum pump or actuator is broke. You can test for vacuum to troubleshoot too. Easy fixes, or get rid of it all, including the vac pump by using manual actuator.
oil in the intake is common, and it gets in boost line.
I wouldnt worry too much about the gauges compression fittings leaking.
