Acesneights1
I will check it out. Thanks.
Yes, the newer engines have the oil squirter blocks, and they probably aren't as strong as the 94-95 blocks, but you also have a lot fewer miles, and properly set up, you should be OK. Don't forget that Tim (Turbine Doc) also has a later model one IIRC, and he can outpull most of us around here.
-Rob![]()
