My 94 had a bad headlight switch that stopped the brake lights and the tail lights from coming on. A new switch in there and all was well. The stock ones were known to suck and get hot, hot to the touch, as well as cheap replacements. I got the new more expensive one, maybe Delco, apparantly designed correctly for the load and it never gets hot.
Did the brake light come on solid or flashing at you for that kind of problem? Did the master cylinder empty out or does these have a valve to stop pressure to leaking lines?
It is also possible one of the 194 bulbs has shorted out. I recently had one on the project CUCV that caused all the front lighting to short out and not work at all.... literally just a single 194 bulb. It could also be one of the gauges too, how knows.
The 'mag' wheel cleaner is some wicked stuff. Hydrofluoric acid I think. It'll etch bare aluminum. (you know this)
You've got some patients sir!
