2 micron is a restriction right, then ontop of that the fuel must make another 20' to reach IP. Then if he has another filter close to the engine....blah blah. I did say "could" be
Weird looking lift pump? Looks like a pipe bomb.
I can't see how having his filter there would make any difference as long as the 2 micron is AFTER the pump then he's ok.
One injector is randomly sticking. Loosen injector lines one at a time to find it,then take that injector apart. You will probably need a visegrips to pull the pintle out,polish it up real nice and reassemble.
It hard to guess what the problem is: injector or lifter? Like said crack one line at a time and see if it go's away.
Has the stalling problem gone away?
I wonder why it would have stoped stalling unless it was just air in the line?
Ticking sound will go away if its an injector when you crack the nut loose. Rev it up alittle as the tap was much louder above idle.
Could the stalling have been solved when I increased idle speed?
Could have, or the air was purged.
Are you running roller rockers?
