Hink
Overkill Is Underrated
I can just see them in his avatar... That's exactly what I had in mind. : )> But I'd like to see a better picture.@Paveltolz show him your vents!![]()
I was eyeballing that as we were contemplating the situation. Good to know it's a known solution.A cheap and effective way to vent your hood is so simple, it's almost ridiculous, but it works well. Remove the black rubber seal that sits on the crimp atop the firewall. It seals to the underside of the hood. With it removed, you now have a 1/2" air gap that totals almost 24 square inches and is in the LOW pressure area under the cowl, not the high pressure zone a few inches higher up at the base of the windshield., so it actually helps draw air through and out of the engine compartmemt. Idling at temperature with the fan engaged, you can feel the hot air pour out. Another advantage in the winter is that it helped keep the windshield clear and the wiper blades de-iced, too, when driving!
I should clarify that all the numbers logged above are with the hood on and afterwards with it off, I didn't get numbers but they all improved.
