Will L.
I agree with the amsoil or the mobil 1, and the weight of the oil. And I apologize for the bad call on the first waterpump pic, the flash made all the difference. Plan on the better duramax fan and a new fan clutch in the future. Fan clutches should be replaced every 5 years. @Burning oil - good catch, thanks for the correction. Last thing I want to do is mislead somebody.
Yes you can switch to synthetic even if it has never ran it. The concearns of going coventional to synthetic and back are mostly urban legends. The only issue we ever really saw when i was working for unical was some types of seals would seep oil.
Valve covers might depending on what they used. Your rear main wont. The front might, and the oil cooler hoses might. But the hoses you are changing anyways. The hardest part of replacing front seal is removing and installing the harmonic balancer- which should be replaced every 100,000 miles if its an AC Delco. 1/2 that if doorman. Or if you can pony the extra cash, a fluid damper will outlast multiple engines.
If you still have the phone number to the old owner, you might pile up parts changed last questions and give a call. Most folks won't mind sharing the info after it's gone, and now that the sale is made they won't "stretch the truth" on something.
