Husker6.5
Won't work. Differences between 94 down and 95 up stampings for both the floor pan and inner door panels. The seats for sure will NOT bolt in because of differences between the transmission/driveshaft hump and seat mounting point location/configuration (Experience, already tried retro-fitting 96 60/40 into 94 bench, no-go without EXTENSIVE modifications to the seat frames, same true of the bucket seats). The inner door skin stampings are different and you can't easily swap the door panels as mounting points for sure and most likely switch mountings are different as well as door handle configuration.
Need to use a diesel dash for the WTS and WIF lights as well as the diesel tach, but I'm not sure if all the harness plugs are the same between 95 up and 94 down as well as pin locations, etc.
