doober
Before replacing the IP I would take that resistor wire harness off the IP. If it is still there it is connected to the OS on the IP. Give that a shot and see if it takes care of the problem.
Mine acted up like yours is and I unhooked the harness from the OS. It had less power and I had to crank the engine over longer to get it to start but the issues went away. So I ended up replacing the OS and it took care of the problem. I also was having the code 18 show up. I had 240,000 on the original pump when the os went bad.
