- Staff
- #21
Go with a egr blocker plate, to many problems with the deletes, and they require a tune as the delete does away with the egr valve and intake heater all together. Run the stock intake with a good oem type filter. Pcv reroute is a good thing to do, and an exhaust won't hurt(all you really need is to ditch the cat, the oem muffler flows ok for low hp rigs). You have several options for tunes out there. You can have somebody flash it, or you can do an exchange ecm from most tuners as well. For a basic truck, I would do a dsp2 tune. Go with a tow tune with turbo brake(you can also add in a toggle switch to a factory tune to get a turbo brake), and an econ/daily driver optimized tune to help the mpg when running light(increases of 1-3 mpg are fairly common with a good tune when running empty at 65-70).
