A friend of mine wrenches at a company in Vegas that has 10 of them all set up identicle, all bought new within 6 month timeframe.
2 of them fight heat, one in testing we found would heat up from cold idle to regular temp in half the time, the other in 3/4 the time of the other good trucks. Care to guess which 2 trucks ate injectors first?
Something has to be related IMO. I don't know these engines- but something is askew. I know several other guys that run them and have had many in the fleets I played in. Only 1 other truck overheated up like his 2, It also ate injectors.
I believe it is a rare problem, but it's there. I'm convinced it's something in fueling. Mechanical or programmed I have no guess. The friend of mine dealing with the 2 of 10 issue had me intro him to a couple of dealer techs- treated us to lunch- both guys have seen a couple trucks with it, but nothing ever conclusive. No response on possibilities from the factory (at least back then). So we're guessing 10ish in a city of a million people.
Two things were consistent in the problem ones they agreed on- injectors wiped out way faster than normal. And once heated up you had to shut off the engine- idle, slight raised idle, etc would not cool down the engine. You had to kill it for 10 minutes or so and restart- then you would cool back to normal as if nothing happened.
Remember the high acidic skin oil during pregnancy thing ruining bearings GM figured out in the 70's? It could be some off the wall thing that is causing it. Being made in Ohio, maybe a curse where everytime the Cleveland Browns Lost?- nah, not that many problem trucks.
We all harass WarWagon about able to break a steel ball bearing with a rubber mallet. But to be fair he works them hard and talks trash to all his diesels the same. Cummins, 6.2/6.5, and dmax. He's just a no holds barred guy. All I can say is if he can put his stamp of approval on a good pair of work boots, I'll try them next- haha.
@THEFERMANATOR you have you seen any of them have the heat problems down there?
My theory that no one has been willing to experiment on was a snow kit to kill the heat and see if that helped the issue. Not a real fix I agree but a possible solution, especially if there is a fuel issue as the heat cyclic problem.
