96 OILBURNER
Yeah he is, unless he has changes. He is running it on an 18:1 motor at around 22-28 pounds of boost.
I saw a banks sytem on a 80's chevy the manifold is a better design than the 6.5 one,but I wasnt sure about the turbo he said it was making about 10 psi.The compressor side of the hx35 is capable of more air flow than most 6.5s need, the problem is the turbine side exhaust flow.
Didn't ChicagoTDP run a Holset HX?....been running that way for quite some time iirc....
Isn't the ATT a chinese version of the Mitsu turbos ? Wasn't the original prototype TD used a Mitsu ?
Yes a Variant of TDO7-22A, ATT has slightly different compessor, and slightly improved spool up over the TDO-7
