I have run the gm1 on my 6.5 and a wh1c ,welded wastegate on both, max boost with the stock turbo was about 28psi, the wh1c was around 38 psi with the same amount of fuel it ran better with the h1c.When i replaced the 6.5 with the 6.2 I was having some serius issues it had no power with the wh1c so put I the stock stock turbo back on try to get a base line it still ran like crap, I thought 6.2 and 6.5 turbo injector nozzles were the same they are not, after putting in the turbo injectors in the differance was amazing, but still lacking, I then reinstalled the wh1c there was a lot more power and it spooled faster than the stock turbo, I got 60 psi with that turbo ,the hx35 is better with out over fueling they are ok. I had lots of fuel. I was pretty happy with it but never checked drive pressure Im shure it was very high. In a mild aplication the hx35 should work fine with a spring loaded wastegate that regulates your drive pressure ,I now have a pro 52 on it ,it made 50 psi , it lags alot.
