buddy
Active Member
Grounds is a good place to start.
The LP is not run by the PCM though. It runs on startup by that relay by the fuse on the firewall then the OPS when running. could be the OPS, how is your oil pressure guage looking? You getting good readings? because it also controls that.
Although if LP stops running you dont get a limp mode, air in the lines will though. did you mess with the filter assembly at all? make sure all those hoses are secured as well.
