chrisk1500
- Messages
- 875
- Reaction score
- 1
You've got a 25% chance of hitting the bad one the first time, 33% the second time and 50% the 3rd time and 100% the last time you swap.
):h
Too funny.....
That is going to be the plan. I got an injector installation kit ordered from napa, i assume these are going to be the clampless return lines?
BTW, how much pressure is in the returns? I noticed I have one without a clamp on it on the OTHER SIDE (PS) than my head work was done on. Hasn't popped off (except when I cracked that inj I knocked it off).
Attaboy, Matt! This is very good news for the 6.5 crew!!
Take that injector to your mechanic friend and bounce it off his head.
Nah... the guy did good on everything else, just needs to learn about 6.5TDs, like most every other mechanic nowadays.
Wouldn't hurt to go explain it to him, though, maybe let him take one apart and see how it works. Sounds like the guy is somebody you WANT to know about 6.5s, so he can help in the future, Matt!
What did the mechanic do to the injectors? Blow air in it? Most likely fouled?
He took them apart, he thought they were clogged because he couldn't blow air through them. When he was done, I could blow through them with my mouth. Now, I have strong lungs, but not 2000psi strong! Of course I didn't know this until I found them to swap them out.
There must have been some washers and springs plugging it up.
You should take it apart and see what he did to it.
