I installed the new bearings and seal, carefully cleaned off the axle, and I can't get the drum more than 1/3 of the way over the new shoes. The adjusting screw is fully closed. The parking brake pedal is released and all the way up. The parking brake lever is all the way aft.
I posted photos showing the brakes before I installed the drum. The only change I made from the most recent photo was to fully close the adjusting screw.
So now I'm back to my previous question. How do you adjust the parking brake? I posted photos of where the cable attaches to the brake pedal, the connection to the rear cable, the connection to the passenger-side parking brake, and the cable running back to the driver-side parking brake. I see no opportunity for adjusting the driver-side parking brake cable length. I do see where you adjust the passenger-side cable.
Thanks again for all your help.
-jpg
-jpg
