I did attach the brake cable to the arm at the beginning of assembly. There is a joint in the parking brake cable beneath the rear passenger side door. When I was struggling to get the brake shoe nails in place, I disconnected that joint in the cable so I wouldn't be fighting the parking brake so much. Now I can't get the cable reconnected at that joint.
I can take it apart again and start over with that cable joint connected, if that's the right thing to do. I understood that you're supposed to be able to disconnect and reconnect the parking brake cable at that joint.
