nycxjeremyy
Shoot, how can I diagnose these from least bad to worseLooks like maybe a glowplug not working or an injector is sticky or some air in the fuel system.
Trying to keep this motor going for a while, just a lowly E3
Start with the glow plugs. when was the last time you replaced them? what GP's did you use then? the best are the AC Delco 60g's they are self regulating so they won't swell up and break off destroying the engine.
think if the GP's and injectors like spark plugs on a gasser. they need to be replaced at least every 100k. injectors can be rebuilt, but it's getting harder and harder to find legit genuine quality Bosch injectors.
If Your engine has them they will come off of where the oil filter screws to the block and make a run to the front of the truck on the drivers side.Super off topic, but i was told.to replace oil cooler lines, what type do you all recommend? Not sure if mine were done or not, I can take photos tomorrow of them, if someone could point to me where on the motor they would exactly be
Those are aluminum lines that have 45deg flare fittings. shouldn't need to worry about that end. what do they look like on the other end up by the radiator?
on the newer rigs, GM used a type of quick connect that are known to blow out or leak at the engine block. on the radiator side, the rubber hose that is crimped to these aluminum lines tend to deteriorate and start leaking. mine started leaking where they were crimped. I simply replaced the rubber hose with some oil cooler hose and worm gear clamps. (poor mans repair)
what is the best you say.... get the oil cooler line set from Leroy Diesel along with his oil cooler and be done with it. as they say, buy once and cry once.
Yup, a little difficult to remove but not terrible bad.
The 1993 GMC K1500 I had, with the 350 V8, oil cooler hoses run alongside the engine block then up and were screwed into the radiator.You sure what you have your hand on isn't the power steering lines? the oil cooler lines should run along side the block where the pan meets the block up to the front where the harmonic balancer is then transition to rubber under the fan shroud to the oil cooler that sits in front of the radiator. you shouldn't be able to access them from under the hood.
