n8in8or
In about a month I think I'll be ready to start putting together a water injection kit for my Tahoe. I'm doing this for 2 reasons: 1) to make the air more dense so I can better burn all the fuel my IP is putting out and 2) so I can keep my temperatures (EGT and ECT) in check when I'm towing. I'm starting the thread now so I can share what I'm thinking and have the ideas vetted by you guys that have knowledge and first-hand experience on this subject. Take a look and let me know what you think.
Pump
@FellowTraveler turned me on to a 1000psi 12v pump a while ago. The high pressure of a system like this should make an even finer mist out of the nozzles.
http://www.saferwholesale.com/DC-12...0.6&gpla=pla&gclid=CPeQtoK1pckCFdgVgQod5uMFDA
Control
Stage 1
I'm planning a 2-stage system. I want the 1st stage to kick in at a boost level just above normal highway cruising boost so I'm not sucking water while driving down the highway, yet not so high that it can't get in front of high temps before they get too high. Also so I can get some benefit from denser air sooner in my boost curve. I am going to accomplish that through a simple adjustable hobbs switch.
http://www.ebay.com/itm/Honeywell-H...ash=item3cfc51ddfb:g:AI8AAOSwbqpT2paP&vxp=mtr
Or I may run an electronic control for this stage. Something like this that has a built in external control.
https://www.amazon.com/dp/B00BFF7UO8/?tag=jhuntlink-20
Stage 2
I want the 2nd stage to kick in at either a higher boost level OR a preset EGT level. I found this electronic control that can control an external control from 2 different channels. I think it will be slick at not too terrible a cost.
https://www.amazon.com/dp/B00JXUVEMQ/?tag=jhuntlink-20
Reservoir
I found an aluminum water tank on Amazon that will fit in the space between the rocker and the frame. Since it's aluminum it will be more durable in an exterior location than a plastic one. It has a 5 gallon capacity which is hopefully enough for normal usage. I will run a tube into the rear wheelwell for refills. I would be nice to add a water level sensor of some sort as well so I know when I'm getting close to being out of water without finding out the hard way.
https://www.amazon.com/dp/B002B91NAE/?tag=jhuntlink-20
Here are where the questions start:
Tubing
Any thoughts on what tubing to use for a 1000psi system?
Nozzles
It looks like Cooling Mist has some nice nozzles but they run a lower pressure system. I was thinking about calling them to see what their nozzles would work like in a 1000psi system, but any input here is welcome.
Nozzle Sizing
I'm guessing Cooling Mist (or another vendor) could help with this as well, but any input here is welcome as well. Rough numbers for sizing I think would be having Stage 1 sized for 200 horsepower and Stage 2 sized for the additional 150-200 horsepower. Thoughts?
Nozzle Placement
The easy place for these is in my homemade upper intake, but I don't know if that's optimal. I kind of like the idea of having them plumbed in the floor of the lower intake plenum pointing up against the incoming airstream, but I don't know yet if I have enough clearance between that and the IP lines. Any input here is also very welcome.
Here's a picture of my setup for reference. I'll try to get a picture made with labeled locations so nozzle positions can be clearly and easily discussed. It's a pretty short intake run, so not too many places to choose from.
Let me know what your thoughts are, thanks!
Pump
Control
Stage 1
Stage 2
Reservoir
Tubing
Nozzles
Nozzle Sizing
Nozzle Placement
