Will L.
Oh yeah, on the hoss if you make your own kit, go toma hydraulic hose shop and have them make a pressure washer hose. There are some thpes of hydraulic hoses with reusable ends so you could cut hose to lemght and thread on the ends. Imo get somehong available to you local, so if there is change or problems you can deal with it easier.
On the nozzle placement, how much room is there in the plate you made the the last 90 attaches to directly on top of the intake plenum? The boosted air is expanding right there coming out if the hose and dispursing into the 8 runners. The expansion of air is where the flow will create a small natural cooling effect from it expanding there, seems like the perfect spot to me. Maybe 2 nozzles, 1 forward and one rear both shooting slightly inward?
