doober
Hey Guys, On my 92 6.5 pickup my clutch pedel has become harder to push. It is the NV4500 manual transmission. It is pushing hard enough that I broke out the bottom of the plastic master cylinder housing. I have since put a new master cylinder on. I have searched around and would like all the experts advice. I even stopped at a transmission shop and they told me to start by changing the Slave cylinder because that could be corroided up and causing the pedel to push hard. I don't know if I am buying that though. I have the exterior slave cylinder and it would be easy to replace if you guys think I should start there.
It feels like to me as though the throwout bearing isn't sliding smoothly on the aluminum snout. The strange thing about it is when I leave in the morning the clutch pedel pushes pretty easy. Once down the road a few miles it starts to push harder. You can start to feel the clutch pedel sorta pulse all the way down. Almost like the throwout bearing has turned at an angle on the shaft and it acts like it is catching all the way down the shaft. Why it doesn't do this for the first five minutes of the day is beyond me.
I took the truck to the cities last week and I was worried I would blow out another master cylinder because it started pushing pretty hard. I could live with it but it just isn't safe because you never know when the master cylinder will decide to fail.
You guys have taught me to research all I could and not throw parts at it. So instead of just putting on a slave cylinder I am asking you guys for advice first before putting on the slave cylinder. Thanks for all your help guys.
