Mudbath
Old Smoky
"I believe that the TCC must be locking"
I wonder if this is the "hickup" or "fishbit" your feeling?
Oh and that goes to show you that PowerService is still inadequate as a lubricity additive to ULSD. I'm not even confident its cetane improver does anything. I have been meaning to try Red Line's RL-3 diesel catalyst and cetane improver with the 2-cycle oil too.
buddy - I am curious why you suggest no more than about B5?
Mainly my ignorance on its properties and lack of my own research to prove to me its both safe in the system and does not interfere with the OS. If something has a cloud point before diesel I kind of rule it out as something I would want in high concentration in the fuel. Bio/veggie has much higher cloud points, and its variable based on its base stock, but generally near freezing (32F) compared to negative temps of diesel. I wonder its affects on the OS itself, if it leaves a film of some sort that will require you to remove the OS and clean it and reinstall. This is something I have not seen people recommend, but I have heard of helping. This similar problem could be encountered from using the wrong lubricant, with solid lubrcicants similar to graphite. Seen that in the LubroMolly product. I realize its not the same but there are things I wouldnt wipe the lens of my camera with, detergents and other stuff as well, dont know if additional acids in the bio will affect it. So I kind of also default to Stanadynes warnings or recommendation to not use higher than B5 in a DS4. Is IP warranty a consideration? Fuel lines going to be eaten by bio? seals need to be changed? Seals in the IP going to fail prematurely?
There are ways to combat temperature issues that makes it work great, but I don't know the long term affects. An IP that may have lasted 6 years on B5 may only go 4 years on B20 or 2 years on B99, ect... I just don't know. I don't know a US diesel engine produced that will warranty past B20.
It may be similar cloud point in some mix of biodiesel, I was looking at some differnent sources like this one that shows it quite different.Ok - that all makes sense. I ran mostly B100 all summer in both trucks last year. No effects to date other than premature filter failure as it got colder out. I think that was more a fuel heater issue than anything though.
FYI the cloud point of Summer USLD is about the same as good quality B100.
I am pretty sure in terms of warranty - that no manufacture can deny warranty for running biodiesel as its a certified diesel fuel. Hell, ASTM specs for biodiesel are much more strict than USLD!
Anyway... on with andy's problems! (well those that we can solve!!)
