alphadeltaromeo
Diesel Enthusiast
Sandersville GA is approx 3.5 hours drive...a ways. I read through the quick disco hose post that mudbath linked to...a great post. Thanks for the input.
Ok, so let's assume that the cooling system is working exactly as it should, with a clean RAD...what should normal operating temp be at 65mph on a long drive?
Good point on the aircleaner. The heating up issues I had on the grades coincided when I was still running my "cold air" NOT intake the PO had installed. Now that I have the AFE set up and have isolated the draw to come back through the fender only, I've not seen temps above 195*. Still, I'd rather have the K47 or another boxed in set up I've seen in prototype only.Last i checked using GMTD Scanner i was running 188*-193* I saw 196* on a long hill unloaded 90* ambient air temps. That is with a clean rad, dmax fan, and modified fan clutch. Those were also before the K47 intake, straight pipe, and tuning.
I think Napa sells a replacement barb fitting that addresses the restriction for that.
Andy - if you cant get the fitting out, let me know. I am about 90% sure I have another housing kicking around from my engine swap.
Glad to see you are figuring things out. Now if only you could find a jump seat for the back to fit all your kids in it!!!
You really should have looked for a retired school bus for the size of your family!!
Bill Heath will treat you right, and is the 6.5 Guru and will share that knowledge if you need to give him a call.
