I gotta get a clutch for it tommorow too. Anybody ever use centerforce ?
http://www.summitracing.com/search/?keyword= Centerforce DF987983&dds=1
After reading Dave's horror story I want to make sure I get good parts.
Really like the look of the RhinoPac clutch in my K-5 now. Looked to have kevlar in the disc(red colored strands of fiber). It was Pricey though at close to $200.
Avoid Perfection/AutoStoned TO bearings. One in the same(same part #). The clutch is good(never was able to slip it), the throwout bearing sucks.
I did a bunch of research since i had plenty of time and the 6.2s had 2 different clutch kits from RhinoPac. The 04-087 has Nylon in the clutch hub where the splines go, to cut down on gear roll noise at idle. The 04-122(the one i have in there) for 88 to ~91 or so, doesn't have this nylon in the hub. It's all steel. No nylon to wear out, and they do wear out.
I doubt the conversion from dual to single caused the balancer to pop on yours.
The 6.2 had the solid flywheel all along. The engine in my shed has a solid flywheel straight from GM in front of the SM465.
The 6.5 did have a solid flywheel to start with, then they went to the dual(94/95 i think) then they later went back to the single after the duals started coming apart.
Oh, do yourself a favor. There's a drain tube onthe back of the motor for the engine valley. This
did not come on vehicles equipped with an automatic(my engine didn't have one but the factory 4-spd engine in my shed did). This prevents anything from dripping on the flywheel/clutch. I didn't have it installed as i didn't know. It's in there now.
Also make sure there's a pilot bearing/bushing in the crank snout. Again, autos had nothing there. If there isn't one that could be the shifting issues your having. I'd run a bushing over a bearing. If a bearing fails the hardened rollers chew the input shaft to shit. If a bushing fails, it just turns to dust since it's a softer metal.
If you need a bushing i have one here brand new in the plastic still for a 1 1/8" 10 spline input shaft. 90% of the kits come with the bearings.
Also regardless of where you order parts from, or the brand, look everything over 200% before installing it. Thanks to UPS i turned down 2 clutch kits due to friction disc damage(physical cracks) before i got one that wasn't damaged.
As far as the CUCV magically loosing 1.5 gallons of coolant is not a good sign. Oil milky? Hope not.
I'd look for leaks in hoses or even the water pump itself before ripping that engine apart. This goes double if any are original.
