1995yukon65
Good luck. Hope your luck stays good with this one. If not just message me... lol
I can get the ARP head studs for $174.
. What the heck is all that crud on the valves though and why are the heads covered in soot in the combustion area so badly ? Is that from him running the truck out of time ? I drove it up and down the block a few times after I re timed it so I would think that would have burned off.
You may want to remove the rubber motor mount clamshells from the frame rather than just the through bolt. The NV4500 is tight to the tunnel on these. Very little room to go up to clear the clamshells.
