iamdave0887
Here Comes Chaos.....
That drain pipe for the engine valley is discontinued and I didn't have time to try and find one. Not sure what it looks like as I have never seen one but I made this little ditty up. The pic was snapped before I secured it to the bolt hole with a clamp. I flared the end in the valley and packed snot around it. Cleared the flywheel no prob. Better than nothing right ? I am so ****ing pissed. I bought the bracket for the starter and forgot to chase the hole while the engine was on the stand. So I go to pu the bolt in in the truck and the ****ing thing snapped in the hole. Mother****er...:mad2::mad2::mad2::mad2:
Ran out of daylight but it's in. Hopefully get er runnin tomorrow.
Almost had the snapped starter brace bolt hole problem with the K-5 since it was missing the bracket when i bought it and the hole was packed with crap. Got the bolt stuck and broke a 1/4" drive socket trying to remove it. That's when i stuck the 3/8 long handle ratchet on it, said "well **** it" and pulled and it popped free. Chased the threads and that was that.
That tube looks just like the factory one. It's nothing more than a piece of steel line with a little flared "lip" on one end(like the bubble at the end of steel fuel lines) so the tube stops there. Pack a little silicone around it to hold it and then the clamp bolts to the small hole that's right below your custom tube.
I would've made one had i not had that spare engine in the shed.
I fell that engine will slowly be picked apart instead of rebuilt and running at this rate. :hihi:
