TSM either changed names or sold out....
Rustic Disc Brakes sells disc brake conversions, pinion and transfer case brakes for cars and trucks.
www.rusticdiscbrakes.com
I checked their product line.
Some mighty nice stuff.
I was looking at a conversion for the 59 Dodge W100 but they list only two wheel drive applications for Chrysler products.
My step son, 1965 GMC 1/2 ton.
He stayed with the drum brakes but converted to a power brake booster.
IDK where He got the vacuum booster and master cylinder, suppose to be matched set from.
He could not get any brake pedal after gravity bleeding the brakes.
He calls, I go.
Checked out a couple things for trouble shooting, then, unbolted the master cylinder, thinking the push rod was not allowing the piston to return fully back to the refill position.
Nope, no tension there when the bolts is off and the maste placed against the booster, fit right up with no gap.
An adjustment bolt and lock nut, extended the bolt as far as it would go, still no touch to the MC piston.
Had him push down the brake pedal, did some measurements: long long way off.
Went to my house, dug through the longest metric bolts of that size and thread pitch and screwed that into the booster rod, adjusted it so that the rod held the master just off the booster then screwed the bolt in unitil the master just set against the booster.
Bolted it all back together then He had brakes.
What a sweet and solid old truck. Inline six. Someone had pulled the V 6 and installed this I six. He scrounged the country side and somewhere come up with a V-6, condition unknown.
I think someday He will go through that V-6 and stuff it into that old GMC.
