It would basically turn it into a piece of wood, and when all is said and done, unscrew the 2 1x8 sandwich and you'll have a gasket as perfect as your cuts for sure.
Gasket Works USA can make me a set .043 thick for $ 210 , it will cost me around $ 100 just for copper so getting them already made don't seem like such as bad idea. They can also make .054 thick.
I still have the Cortecos,the fire ring is to narrow for an o ring. I pulled both heads this evening. Same old story,leaking at the ends. I checked the pass side head ,it is not warped. I wish I would have let the orings stick out farther ,instead of the recommended .010 thousandths .
