uniquediesel
1/4 mi. Fan
- Messages
- 245
- Reaction score
- 38
The studs hold, they just allow coolant to enter the crankcase, so your lubricating system is unhappy.
One of the beefy bolt companies like ARP does make a set of non-tty bolts for the 6.5. Cometic sells these bolts (not studs) with their gaskets (or, I would assume, by themselves as well).
Honestly, if your making 300 Flywheel HP or less, use the TTY bolts, they're just fine and you don't have to worry about leaks. Every now and then there will be a "soft" bolt in the bunch, but it's really obvious during install when it happens (feels like the threads pulled down below).
