well i had #2 glow plug go bad ,i let the garage convince me i should change them all witch makes sense,but now the last two,one on each side have broken,has anybody been able to drill them out is there enough room or the engine has to come out,any help would be appreciated thanks mike
Here's what I had to do for the Broken one:
Well, we got it out yesterday!!
Took just under 2 hours.
I used a Thread I found on another Truck Site googling to see what steps needed to be taken.
Tools needed:
Digital Caliper (So you can know how deep you can Drill before hitting the Electrode in the GP)
Drill
LEFT HAND 13/64" Drill Bit
1/4-20 Bottoming Hole Tap
LEFT HAND 11/32" Drill Bit
Pick Tool / Chisel / whatever you can find or use
Vacuum
Vacuum
Vacuum
Drill the Glow Plug Body Flush to the Head with the 11/32" Drill Bit
Drill the CENTER on the Glow Plug with the 13/64" Drill Bit
Tap the Center of the Glow Plug with the 1/4-20 Bottoming Tap (This is a safety precaution. If you can't get the GP out, you can Thread a Screw into it to then pull it out)
Now use the 11/32" Bit to start drilling out the GP Body completely. You need to be 100% Spot-On so you don't damage the Threads in the Head.
Once you get past the Threads, you should be able to pull the GP out. Before you do that get a Pick Tool to get out any remaining Thread Material that may be in the Threads in the Head.
We used a Thread Chaser just to make sure the Threads were still good in the Head, put the new GP in and everything is good.
