3500GMC
What T F, over
...(need a bearded emoticon walking with a cane)
lcoot: <--- Will.
Sweet! I'm glad there's a happy end to the story. You were sure to use some Lock-Tite on the new GP, right?
But was it the regular red, or the GOOD 272? You don't want that thing ever coming out again do you?Haha, yea, I'm pretty sure we used Red!
Wow! That is hilarious sold the truck! Glad you got I fixed. As far as not changing anymore, maybe you should just do the rest now while your in practice.:lmao:
Glad to see you got it James. Has to be a big relief. FWIW, I had 2 fail at 200k on the left bank and one at 260k on the right bank so the OEM units hold up a long time.
Oh joy...GP #4 just went out!!
I need to borrow Will's crystal ball. :hihi:
Or he's been down this road before and knows once 1 goes out, the others start droppin like flies!
Well, we got it out yesterday!!
Took just under 2 hours.
I used a Thread I found on another Truck Site googling to see what steps needed to be taken.
Tools needed:
Digital Caliper (So you can know how deep you can Drill before hitting the Electrode in the GP)
Drill
LEFT HAND 13/64" Drill Bit
1/4-20 Bottoming Hole Tap
LEFT HAND 11/32" Drill Bit
Pick Tool / Chisel / whatever you can find or use
Vacuum
Vacuum
Vacuum
Drill the Glow Plug Body Flush to the Head with the 11/32" Drill Bit
Drill the CENTER on the Glow Plug with the 13/64" Drill Bit
Tap the Center of the Glow Plug with the 1/4-20 Bottoming Tap (This is a safety precaution. If you can't get the GP out, you can Thread a Screw into it to then pull it out)
Now use the 11/32" Bit to start drilling out the GP Body completely. You need to be 100% Spot-On so you don't damage the Threads in the Head.
Once you get past the Threads, you should be able to pull the GP out. Before you do that get a Pick Tool to get out any remaining Thread Material that may be in the Threads in the Head.
We used a Thread Chaser just to make sure the Threads were still good in the Head, put the new GP in and everything is good.
