floyd400
Can you confirm that the DD bracket will work with a GR starter? Weighing my options here.It your truck, your job to make the call. Our job is just offer advice to keep you from making the same mistakes we have in the past.
Whatever you do, don't run it without the bracket. The weight of the starter can and has been known to crack the mounting pad off the block basically ruining the block.Update on my starting issue, I replaced the starter with a reman GR unit from Autozone and she fired right up! The DD bracket could be made to work easily enough by cutting it shorter and drilling a new hole for the stud on the starter but I'm going to order the correct one.
Pics are in post #2 of this thread: http://www.dieselplace.com/forum/63...-engine/791473-starter-bracket-do-i-need.htmlX2! I'm panicking for you right now.
When you get the new one, can you post a pic of the two side by side for the next guy looking for this solution? And my own curiosity of course...
