Johnny Rotten
Hey guys new member looking for some help.
I have a 2003 H1 Hummer 6.5L with 40K miles on it.
I'll start from the beginning, back in September I was driving home from work, turned on my street it has a slight incline and a turn, as I was approaching the turn my truck turns off unexpected, coast to the side and tried to restart it, nothing so I think my PMD was toast so I change it out quickly thinking I got this, tried to fire it up again, nothing, called my son and he tows me 1000' home, get the truck into the garage, try starting it again, nothing, for whatever reason I decide to pop the water drain on the FFM and it fires up, okay WTH! I start asking questions on the HML (hummer forum), Will L 95 (member here) starts giving me suggestions I do the following: install a fuel pressure gage inside the cab, with low PSI reading I then replace the LP with Leroy's WHLP, PSI readings double to triple, truck is running great again, some time passes and every time I drive it I'm watching the PSI reading and now I'm noticing the reading are going back down, 2wks ago I drove it on a 4hr round trip everything felt ok except the psi reading, so Friday I decided to replace my fuel filter, pulled it out and looked inside the FFM and found this:
So I pull the FFM out and give it a through cleaning:
Got it all back together and took it for a 3-4 mile test drive, drives ok other then low PSI reading, at this point I'm thinking I have a faulty PSI sensor or gauge.
Take the wife out to dinner Friday night, as we turn on our street, climb the hill and in the same spot my truck died in September it died there again, geez!
Resurrected my post back on the HML and Will 95 mentioned fuel bugs, I'll admit I had to google that one..
what's my next step?
Thanks JR
My post from the HML
http://www.hummernetworkforums.com/viewtopic.php?t=244344&postdays=0&postorder=asc&start=0
Thanks JR
