625fireman
I have injecter-itis
Looking into redoing my entire fuel supply from tank to IP. What are y'alls opinion on wich is better FRC10 or Raptor?
The Raptor and the Mallory I run will kill the engine when (not if) they fail. The Walbro is flow on fail.
In the end it is your money. Get what you feel will keep you happy and safe from breakdown.
Thank you for your communication.
All units have a pass through capability. The AD's have a ball in them which stops pass through flow under normal operation. When there is power to the pump the ball is pulled into position to shut off pass through flow. When there is no power to the pump, the ball will lie in the pass through position allowing a pass through flow. The design of the Raptor does not include the ball. It has pass through capabilities whether the power is on or the power is off.
Please do not hesitate to contact us if we can be of further assistance to you.
Thank you.
I pray you have a great day.
Toby A. Parks
PureFlow Technologies, Inc.
Quality Assurance Manager / Technician
Tech Cell Ph No (573) 694-8833
Sales Office Ph No (877) 463-7363 or (573) 635-0555
Fax No (573) 635-0778
More info on Pureflow pumps for consideration:
Forgot to mention: Ken has said on another forum he has driven 200 miles on a raptor 100 with 0 fuel pressure. That was part of that whole lee auto ranch/cummins mucked up install thing. Wasn't the pumps fault, improper wiring installation. Pump fired right up once fixed apparently.
Damn all this talk about fuel pumps now I want a raptor for my truck it seems the 400.00 is worth it . I am still happy with the Walbro but it sounds as if they fail about as often as the OEM. I do have the OPS relay mod and extension hose from Leroy and up to this point no problems at all with the Walbro I would like to add a pre-filter setup and loose the sock in the tank. Thinking of a fuel pressure tap I really should be monitoring those fuel pressures as well. This would provide a better indication and since it is post FFM you can tell if you need to change that filter sooner if you get dirty fuel. All these gauges will make the truck cab start to look more like an airplane cockpit than a truck cab.
