great white
I dunno.
Gotta be a reason Bill runs them on everything he owns.......
Because he sells them ...
Nope.
I've talked with the man directly.
That's not the "why" and is an unfair assumption about his motives. To be blunt, it's flat out wrong.
simmer down...
I never look at the damn things(stock) with an oil change or otherwise.Only time i look at them is when i rebuild an engine.inspect and back on it goes.Technically it is only $300.00 more than the dealer part, wholesale. So it is excessive spending of $300.00, not $400.00. Every 6.2 6.5 I have seen, 5, have needed one. The one I replaced only made it 30K, dealer part.
You can sell it used later, or put it on the next engine because it is going to outlive the engine. I can't see it being a bad buy.
Now you can forget about checking it every oil change...
The one on my 89 is been on there now for 700 k,the other ones both close to 400
Better value in the hotter climates where rubber doesn't last as long...
Don't have to. You're interpreting emotion in a post where there was none intended.
I expected a noticable difference and didn't so as the title states, in "my" opinion yes, a waste. Plenty of 6.2/6.5s that have gone 300k miles on the original balancer. Unfortunately my 93 was not one of them. Seeing the carnage spooked me into this but now I realize there was nothing wrong with the one I took off and even if there was a quality stock replacement would have sufficed. Not saying these things are junk or anything, just saying 400$ is better spent somewhere else.
I do agree, if I didn't get mine for a steal like I did... I would find it very hard to justify 4 bills for something that doesn't sit atop a motor and make gobs of torque. I would however, if purchasing new, feel way more comfortable with a 250.00 price range of this damper. They are way over priced.
Mike
I'm not getting into this with you again.Good, then dont interpret my post as an asuumption of motives.
Its obvious your OE damper wasn't broken thus causing the problem so how can you fairly comment on this piece until you fix the vibration???
We'll glady spend $1000's of dollars in hours and parts to soup up our engines but scream blue murder on an item that WILL save your engine and help it live a long life, kinda funny, don't you think?
I know mine is a 6.2 but the difference is night and day, the engine noise changed so much, it was more of a hollow knock instead of a hammering type noise, the exhaust used to buzz-stopped, the engine smoothed right out, and the biggest benefit was you could see the v-belts weren't being whipped around so badly anymore. After initial tightening of the belts, you never have to retension again. Sure, I can spend $400 elsewhere and there wasn't anything wrong with my OE one but if you truly understood how much abuse diesel cranks take, you'd put one on every diesel you owned, and remember, this will outlive your truck so if you buy another one, simply put it on your new engine,
See above.
I have had many 6.2's last over 330k miles with the stock damper and the reason 6.2's eat v belts is thanks to Gates rubber company and them discontinuing the proper belt.
