bison
No kidding!Looks good Simon.
I'm glad I built mine when I did, things must be a little pricier now. Mine was about $80k but I built my own boiler and helped my brother wire it. No permits saved about $3k too.
Paint likes to separate the surface layer of OSB. Just sayin' so you aren't surprised (pissed) and jump off the scaffold or something...
The water (or mineral spirits) in the paint will cause a rough surface from warping/lifting the surface fiber layer. I don't know any other way to put it. Try painting a dropoff piece and see how it comes out.Huhh?????
wow, that's a boat load of concrete. I about crapped when I saw that you poured the whole thing - figured it would only be a partial and the rest stone or something.
What is the black stuff on the exterior under the steel?
Just curious if your trusses were rated for that OSB to hang on them? That's not typical and is a LOT of extra weight.
What did you decide on your doors? If you already got them, then I missed it. Dad's putting in Wayne Dalton overhead doors with openers. They came in at just under $5K installed for one 20x14 and one 12x12, both insulated. Pretty good price, we thought.
The other two doors are just sliders. One is a 28' opening and the other is a 20'. Both of those slide on the inside of the building, so there's no need to ever worry about digging snow out of the way in the winter when we open them.
Yeah, its a lot of crete in there.$11000 worth,and 4 grand to lay it.No use complaining about spilled milk.
Its some kind of one way moisture barrier
AK said it,OSB is lighter than sheetrock[called drywall in canuckland](cheaper too,at least around here it is)
The Doors are ordered,around 7 grand installed,one 14'w x12 h with electr opener,the other 20 x 12,chain hoist opener,both insulated and overhead( not much choice for brand up here,only one supplier in this area).:nonod:
In the US everything is cheaper:rolleyes5:
I'm still waiting to get those on my doors.
If you don't do it right away it doesn't seem to happen.
't was my wife's idea,who am i to say NO?
Its the old house stove,it'll have to do for now,its just a back up.The wood stove has it's work cut out for it.
I bet she'll do better than you think though....
Will say again..Fabulous building.
Trying to figger the CAD compared to USD- also- When you say 'ton' is that 2000 pounds? Is a Canadian ton the same? Lotsa stone nonetheless.
That's what I did. Blowing up in cold weather. HUGE difference. A small oscillating (8" or so) fan on a shelf behind the woodstove works well too.Ceiling fans would help circulate the heat.
