bshull
I might be way off base here but open your door while driving down the road at 60 mph or so. You will notice the door will not shut on it's own, there is a dead spot where the door will kind of hang open. Where the door hangs is the narrow vacuum of "dead air" surrounding the sides of the vehicle.
If you open the door a little more it will encounter the airstream beyond the dead air zone and becomes very hard to push open, this is how far out your scoop will have to be if you want to generate ram air at that point on the vehicle.
If you want to test the front quarter panel for ram air possibility tape a couple strings of yarn on the side, go for a drive with a chase vehicle and see what happens, then post a video clip on here. You could also mount a yard stick or something to the vehicle hood overhanging the side with yarn attached every inch or so away from the vehicle to see where the airstream cleans up and how vehicle airspeed affects the airstream. I have not done this but I suspect the results might shed light on what is happening to the side of the vehicle concerning airflow.
Just a crazy late night thought
Brian
Brian
