NVW
My mind just went somewhere completely different.....
):h
):h
):h
I think i know in what direction :smile5:My mind just went somewhere completely different.....
):h
):h
It's more about areas of high and low pressure, which you could also call vacuum or the venturi effect in this case I suppose. It's pretty much the same thing in the greater scheme of it all.
When the air is flowing is past the vent (or anything of shape or void really), you end up with a low pressure area. The higher pressure air inside the fender (engine bay) will want to escape to the low pressure area. This is only a concern at highway speeds, around town isn't going to have enough of an effect to overcome intake pressure differential created by the retreating pistons in the engine. Cheers
):h
The majority of that 95000cuft is getting diverted around the truck and through the radiator, which does not go to the air intake. So that doesnt mean the fender is pressurized that much.
That would essentially remove your high pressure, but may allow more air to circulate through the fender. But it is essentially the opposite of RAM air. RAM air is to pressurize the air intake to stuff more air in, and this would be lowering the pressure in the fender and the engine would have to suck harderAlthough it probably would be cooler from circulation, and not because it would draw the air from the vent. Just as GW said.
If you put a scoop on that could work to pull the air in, but then you would need to see how far the airstream gets divereted away from the fender at high speeds.
