bison
That is the Transfer pump pressure relief valve,don't fart with the adjustment screw. The fitting can't be omitted.This lower IP fitting that everyone should drill out the 4 holes on. I took it out and was having a look at it. From what I've seen there is a check ball in there...anyone know what this is for? And has anyone tried not running this fitting at all and just getting the right sized fitting to go in there instead of this stock fitting that seems to be pretty restrictive?
Thanks
