Veg_Out
Walking J Designs
Are your kits coming with this 1 Barb Fittings yet...looking at your website its still showing the multi-barbed one....and I would be wanting the future release you describe.....
Yes, it's the 1 barb. Thanks.
I'm thinking I should blow through the line from lp inlet back to the tank?
Dan, put a 2 liter soda bottle on the end of your t-handle drain hose. Start the lift pump with the engine OFF. You should get 1 liter/minute with a stock lift pump and 2 liters/minute with the Walbro FRB-5. If you are getting less than 1 liter/minute now, either the lift pump is weak or you have a restriction before the pump.
So maybe Im missing something, but nowhere can I seem to find what size drill and tap to use on the filter manager, nor can I find how deep to drill it. Instructions saying "dont drill too deep" isn't really that helpful. Does it have to be just deep enough to seat the fitting, or do I go deeper to open up more. Because it looks like there's be a restriction just before the fitting starts if you don't go deeper.
I don't have a local machine shop to go to, and for one little hole like this I'd think I could handle myself. I just want to be sure before I do it. I have some taps but no dies, so I want to know I'm tapping it the right size.
Also, how vital is the fitting going down into the IP? I saw that Buddy modified his, but my kit didn't include anything to address that, just a fitting to go on top of it. So, is it a waste of time to run ftb size up to that and have it restricted there?
You should have read my original thread. I laid out how to do it with alot of detail. I was one of the first to try this after TD.
IIRC wasn't it your handywork coming up with the nice elbow fitting at the IP too?
OT - I was working it Putnam CT today. It felt a good 15 degrees hotter there than Worcester.
