jrsavoie
Recruit
Look at your bleeder screw.Any such thing as a bad fuel filter? I fixed ground from frame to head and made a new one frame to firewall, then replaced fuel filter and plugged the blue hose then tried to bleed the new filter nothing would come out of the bleeder hose I heard the lp working then loosened the bleeder screw so much fuel started coming out of sides but nothing out the bleeder hose. Tried it with blue hose plugged and unplugged.
I've had the same issue and on some, I found that there wasn't even a hole through the bleeder. The only place for the fuel to go was out all over around the threads. What mess
