iamdave0887
Here Comes Chaos.....
Will be interested to hear how it turns out with the filter change and several cold starts.
Did you have to add more oil into the crankcase when you added the turbo? I guess its not that much volume added though. Any used oil analysis by chance, or much blowby or coolant loss?
Truck's only been out of the shop for about 2-3 days now. Haven't put but a few miles on it since the turbo was installed. The Banks manual didn't state adding any more oil, but i've always put in 8 quarts, versus the ~7 it takes. The internal oil cooler takes close to a quart itself. Found that out when i had 8 quarts and no cooler(1 quart over) and hooked up the cooler lines and the level dropped to "full".
Blowby doesn't make sense, never did though. The bottom end of the engine is so clean you can read every part number. Even the numbers on the undersides of the pistons. Yet it has a good bit of blowby. I'm curious if the rings just never had a chance to seat considering the evidence shows a very low mileage motor, and i know it sat for over 10 years before i bought it. There's not enough vacuum in the air intake pre-turbo since the CDR isn't working. Going to try building something with a 6.5 CDR to see if i can get it working again.
I'll post my findings on the filter change in the morning. I'm not looking for anything other than reducing the time with no oil in the charger at startup.
