You 2WD guys get to have all the fun!
this one doesn't have the anti-drain back valve so 4X4 might get a starved filter on shutdown/start up unless remote mounted.I can use the 2 quarter on my 93 4x4 with no issue.... BTW that is a gasser filter. I was under the impression there was something different about them but wasn't sure what but I know a 6.2/6.5 uses a PH5 Fram and a Gasser uses a PH13 which are both 1 quart and the PH373 is the 2 quart gasser filter although I used the PH373 on all my 6.2s without any issue ever.
